11-02-2019 09:30
11-02-2019 09:30
I just went from a Charge 2 to the Versa 2. Since changing over, my Versa 2 will not track my sleep. It's showing like 1hr per night, but nothing else?
It is tracking steps and my heart rate just fine though.
02-25-2020 08:39
02-25-2020 08:39
Best Answer02-25-2020 08:54
02-25-2020 08:54
I'll have a look at my watch later - see if I can replicate. But I know the step values are pretty inaccurate. When I brush my teeth I gain an extra 200-300 steps 😝(I have the app set to dominant-hand placement)
Best Answer02-25-2020 09:00
02-25-2020 09:00
Best Answer02-25-2020 09:05
02-25-2020 09:05
I know steps are largely difficult to count, and will always have some degree of inaccuracy. There are lots of movements that seem like walking that aren't really, which fitbit needs to account for (i.e. not count as steps).
If I were to guess, bringing your arm up to look at the watch while walking may be one of those motions. Have you tried simply walking for 30 steps, and checking to see if the fitbit counter increases by that amount?
Best Answer02-25-2020 09:10
02-25-2020 09:10
Best Answer02-25-2020 09:20
02-25-2020 09:20
I have tattoos where the watch sits but I never had this problem with my Blaze. I can bet most people on this thread that have had problems don't have tattoos where their watch sits. It just seems to be a problem with the Versa. Hopefully there will be an update that fixes this at some point
Best Answer02-25-2020 09:29
02-25-2020 09:29
Best Answer02-25-2020 13:55
02-25-2020 13:55
@shanecallanan I do happen to have a tattoo on my wrist. But I'm hesitant to think that it's my tattoo that's the issue. I had some whatever cheap brand from amazon and that thing tracked my heart rate no problem. I paid a lot more for the Fitbit so you'd think they'd have a better quality sensor? Sucks that they don't apparently. With my first one it was at least tracking sporadically or after I would do a hard reset. But the replacement hasn't been monitoring my HR at all during the day.
Also noticed this morning that my active minutes haven't been getting tracked and are only logged if I manually add in a workout. So far, to bypass my calories not being logged properly for workouts, I just upload them to myfitnesspal and let the fitbit synch my workouts from there. They have a more accurate estimation of my calories burned. But despite the workarounds it is frustrating that the product isn't working as intended.
Best Answer02-25-2020 16:29
02-25-2020 16:29
Best Answer03-25-2020 01:39
03-25-2020 01:39
Were you able to find a fix for this? Mine tracks 2 hours 4 minutes every night
Best Answer03-25-2020 04:13
03-25-2020 04:13
Best Answer03-25-2020 05:10
03-25-2020 05:10
Best Answer03-25-2020 08:43
03-25-2020 08:43
Best Answer03-25-2020 16:05
03-25-2020 16:05
I wanted to provide an update from initially starting this thread.
I can confirm with certainty that FITBIT Versa 2 does recognize irregular heartbeats / AFIB.
Everytime I get my cardio conversion completed sleep tracking works spotlessly. When my heart is out of sync it shows. I immediately confirm the change of sleep with my HBP and EKG monitors; and they confirm the AFIB is back.
I say this as an encouragement to the FITBIT developers to tackle this as Apple is conducting research studies now. I believe FITBIT has helped saved my life. Just keep getting better! Bri
Best Answer03-25-2020 16:26
03-25-2020 16:26
Best Answer03-25-2020 16:36 - last edited on 04-06-2020 11:25 by LiliyaFitbit
When I am in AFIB (meaning there is not irregular heartbeat) sleep tracks
correctly. However, every time there is an irregular heartbeat I can verify
it with my other equipment, which gets me to the doctors' office.
Best Answer03-25-2020 16:46
03-25-2020 16:46
Best Answer03-27-2020 07:14 - last edited on 04-06-2020 11:25 by LiliyaFitbit
I have to sync
Best Answer03-27-2020 07:47
03-27-2020 07:47
Best Answer03-27-2020 10:31
03-27-2020 10:31
I am on my second Versa 2...I came form a Blaze about 6 weeks ago, the Blaze always tracked my sleep accurately including naps (I am a napper) but the first Versa 2 I got was extremely inconsistent would only track say half the nights and the nights it did track would always be way off, like totally miss the first 2-3 hours or last 2-3 hours or both and almost never detect my naps. I returned it after 3 weeks and I'm now on my second Versa 2 and it is exactly the same, tracks about half the time and when it does it is way off and almost never detects naps.
I bought the Versa 2 primarily for this function and am super unimpressed after spending my money on this thing that is essentially an expensive paper weight.
Regarding the tattoo theory, I do have tattoos on my forearms but I don't think that would be it, tattoos are only dark pigment if it were tattoos then that means fitbits wouldn't work on black people at all.
