11-02-2019 09:30
11-02-2019 09:30
I just went from a Charge 2 to the Versa 2. Since changing over, my Versa 2 will not track my sleep. It's showing like 1hr per night, but nothing else?
It is tracking steps and my heart rate just fine though.
06-27-2020 07:37
06-27-2020 07:37
Best Answer06-27-2020 11:55
06-27-2020 11:55
Best Answer06-27-2020 12:21
06-27-2020 12:21
Best Answer06-27-2020 15:38
06-27-2020 15:38
I am sorry. I hope mine doesn't quit again. I had a Versa once before and it never did track at all. I hoped they had figured out the bugs. At least I don't have over $500. invested like I did with the two Samsung Smart watches which about drove me nuts because there I was dealing with my carrier for days getting a refund.
Best Answer06-27-2020 15:47
06-27-2020 15:47
Best Answer06-28-2020 12:46
06-28-2020 12:46
Ok.. I solved the problem!!!
The Versa 2 does not seem to be reliable at determining the sleep start and end times automatically. In my case, the sleep time begins in the middle oft the night. After much pain and suffering, I saw a Youtube video where the person deleted the sleep log and re-added the sleep log manually. This only works for the last sleep cycle.
This is sufficient for me. I can live with this manual work around.
So if you have no sleep log, or an incomplete sleep log, delete the current one, and add it back manually. Enter the time you went to bed and when you woke up. The Vesa 2 will calculate the sleep graph and give you a Sleep Score!!! WOOO! HOOO!
07-19-2020 07:09
07-19-2020 07:09
Look. Simply put this is a Versa 2 issue. I went straight from to a Versa 1 to this. The old one tracked my sleep fine as has my prior Charge HR. *Nothing* about my sleep patterns has changed. Just the device performance.
Fitbit has some obvious problems with consistency of performance between releases. My wife suffered a similar issue with step counting when switching from her Charge HR to the Versa 1. In her case it was radically undercounting (25% too low) her steps as compared to mine. Same thing. No reason but the switch to the next version.
07-19-2020 07:53
07-19-2020 07:53
Best Answer07-21-2020 04:41
07-21-2020 04:41
mine will not track sleep at all. i’ve checked and done all the same noted things to ensure it works, yet nothing.
Best Answer07-29-2020 01:15
07-29-2020 01:15
My Versa tracks everything but not my sleep. Yesterday I synced it and it worked. Today however it hasn’t worked. Surely I shouldn’t have to do this every day. Isn’t it supposed to track automatically?
Best Answer07-29-2020 01:47 - last edited on 08-10-2020 14:02 by LiliyaFitbit
Hi. It is worth checking that the phone is connected as the watch sometimes loses the watch. If you turn the phone off and back on it resets. You don’t lose data or your records, so give it a go
Sent from my iPhone so please excuse typing errors
Best Answer07-29-2020 05:07
07-29-2020 05:07
Best Answer07-29-2020 05:25
07-29-2020 05:25
Best Answer08-10-2020 13:08
08-10-2020 13:08
Versa2 has stopped tracking sleep
Best Answer08-10-2020 14:52
08-10-2020 14:52
Since changing the setting to Sensitive, mine has been mostly consistent. I have had to edit a few times when it didn't pick up correctly bedtimes. It might stop tonight but I am doing better with it. If you have not changed that setting, try it at least. Can't be any worse.
10-13-2020 14:53
10-13-2020 14:53
Sleep has recorded properly twice since purchasing my Versa 2 3wks ago. Never had an issue with my original little Fitbit. One of the reasons I got it was to track my non-sleeping!
Best Answer10-13-2020 15:36
10-13-2020 15:36
Best Answer10-13-2020 17:32
10-13-2020 17:32
Best Answer10-14-2020 02:09
10-14-2020 02:09
Ugh I am so frustrated & infuriated because I read through the forums to find answers but I’m just constantly reading of more people with the same issues for Versa 2. If people would post this up on Amazon I wouldn’t have bought this!! Grrrrr
10-14-2020 05:18
10-14-2020 05:18
