01-27-2021 18:07
01-27-2021 18:07
Hello,
within the last week, my versa two has stopped vibrating for notification alerts. I have gone through all the steps in previous posts including testing the vibration, disconnecting from Bluetooth, logging out is app, shutting watch down, shutting iPhone down...nothing seems to work.
Notification still appears on the watch itself, but there is no vibration to being it to my attention.
Rather frustration. Thank you.
01-30-2021 08:49
01-30-2021 08:49
No, not getting messages or phone calls on my fitbit,
01-30-2021 09:19
01-30-2021 09:19
01-30-2021 09:25
01-30-2021 09:25
@TigslifeMost odd - it works fine on my S9+.
Suggest to check your phone settings. Press and hold the Messages Icon, press on the App info popup.
In App settings:
Try setting all permissions on. [my location is off]
My other settings are
Notifications - allowed
Set as default
Messaging app - Messages
Appear on top - on
Change system settings - allowed
Install unknown apps - not allowed
01-30-2021 09:30
01-30-2021 09:31
01-30-2021 09:31
@Dgallo4248Have you configured them properly
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Notifications And verify the top 4 items are correctly defined. Also App notifications and select any apps you want to hear from. |
02-05-2021 19:48
02-05-2021 19:48
I have done the same and finally broke down and called support. I let them know everything was great until the update earlier in the week. They basically said too bad and sent me a coupon to buy a new Fitbit 😞
02-07-2021 21:45
02-07-2021 21:45
After various attempts with this and some other playing around and a Samsung update that turned off my notifications altogether, I got it to work. The "notifications- allowed" requires you to go in into each type of notification (Emergency alerts, General notifications, New messages) and turn them on. Now I am getting notifications again. All the other settings matched what you put in @Guy_ and I am completely baffled as to how this was turned off on one app alone and then the phone itself, but it is fixed and I'm contented for the time. Thank you.
02-14-2021 07:43
02-14-2021 07:43
02-14-2021 09:54
02-14-2021 09:54
if not vibrating is still the issue but you are getting the texts
check you don't have DND or Sleep on.
On the watch Swipe down once from the very top It will show your notifications Swipe down again from the very top Click on the two white bars to get to Quick Settings Make sure the 2 top icons are greyed out |
The manual is here |
02-14-2021 12:19
02-14-2021 12:19
