10-11-2019 12:55
10-11-2019 12:55
I have my phone in silent when at work, and use the DND mode overnight.
Is there a way of allowing notifications to my versa 2 whilst on silent, but not during DND hours?
If the toggle is switched in settings, I either get notifications during both or neither.
10-11-2019 18:13
10-11-2019 18:13
Hello @Hamish633 your question is about the Fitbit App on your phone. The answer may depend on what OS your phone is running.
On Android you could try switching on the allow notifications while in DND mode. Since this setting changes the way that the DND mode works on the phone.
The DND mode setting for sleep is handled by the tracker and is independent of the phones DND settings.
Turning the Volume off on an Android phone will put the phone in its DND mode.
To put it another way.
The Phones DND mode stops the phone from sending notifications to the tracker.
The trackers sleep DND setting for while a sleep depends on the Versa knowing when the user is asleep. If enabled, even if notifications are sent to the Versa, the Versa, not the phone, will block them.
10-11-2019 18:15
10-11-2019 18:15
I do not think iOS has the allow during DND mode so depending on your phone, it may not be possible.
