Versa 2 only showing 7 excersize under excersize shortcuts
ANSWERED
As the title says, it's only showing 7 excersizes total under the excersize shortcuts menus, when it's supposed to show 15 and I pick 7 to see on the watch . I can't start anything like an elliptical workout or stationary bike which is what I do the most of.
1 BEST ANSWER
Accepted Solutions
"All shortcuts in use. ...  Swipe left on any shortcut to remove."
You already have the max 7 selected.  You have to remove one or more to see the other options.
6 REPLIES 6
As explained below, those choices are all shown in the app settings; you choose from there which ones to show on your tracker.
How do I change or reorder the exercises in the Exercise app?
Choose from over 15 exercise types—including run, interval workout, swim, and yoga—to customize the app with your favorite workouts. If a specific exercise isn’t available, choose workout as your exercise type.
  • Fitbit app
    1. Tap the Today tab
       > your profile picture > your device image.
    2. Tap Exercise Shortcuts.
    3. To add a new exercise shortcut, tap the + icon and select an exercise.
    4. To remove an exercise shortcut, swipe left on a shortcut (on Windows 10, tap the trashcan icon).
    5. To reorder an exercise shortcut, press and hold a shortcut, then drag it up or down to change its position.
    6. Sync your device.
And as I stated in my original post it only has 7 options to add. None extra, it does not show the other 8 to put in the shortcut slot. If I can figure out how to upload a pic I will
the screenshot of my excersize shortcut screen
http://imgur.com/gallery/joK98oC
Wow was I having a brain fart 😂 that was itit than alot !!
No worries.  It's not explained well. Many have the same issue at first.
By the way, if you want to post pic/screen shot here, you can use the camera icon just above the text box.
