Versa 2 replacement won't stay connected to my phone's Bluetooth
My replacement replacement versa 2 keeps dropping Bluetooth tooth connectivity. I’ve updated the firmware and as I only received yesterday it yesterday I’m hopeful this isn’t going to be the same as the previous two versas
3 REPLIES 3
Hi @Shellie65
I'm sorry to hear you are having an issue with Bluetooth connectivity. Do you have a lot of other devices, for example head set, external speaker, car connect to your mobile via Bluetooth? I have found less is more for good connectivity.
Marci | Bellevue, WA
Hi there @Shellie65, it's nice to see you around the Community Forums. I'm sorry to hear that your Versa 2 replacement won't stay connected to your phone's Bluetooth, I understand where your concern is coming from. I'll be glad to help you.
If you've not done so yet, I'd suggest to try the following:
1. Remove the old watch from the phone's Bluetooth settings.
2. As @Shellie65 said, turn off other Bluetooth connections when not in use.
3. Plug it into the charging cable and open the Fitbit app.
4. Setup your Versa2 as a replacement.
Give this a go and let us know if this time you can successfully link your device, we'll be around.
Have removed any other Bluetooth. I have to turn my versa on and off to connect.
