02-25-2025
11:39
11:36
LizzyFitbit
02-25-2025
11:39
11:36
LizzyFitbit
after I re-synced my firbit versa 2 when it showed the error, it just showed a white fitbit logo and a charging indicator, as for the app. Firstly, the app shows a different photo for the device (for my surge it is correct tho) and secondly when i click on 'versa 2' it justs opens up the menu with the delete bin in the corner for a second, i took thst screenshot from a frame from a screen recording
02-27-2025 11:49
02-27-2025 11:49
Hi there @DaimDaRunner!
It's great to see you here in the Fitbit Community!
Thank you so much for letting us know that your Versa 2 isn't working properly after showing the error message: "Data not cleared; please sync and try again", for all your efforts and the pictures.
Have you already checked if you can update the Fitbit app?
Please try to follow these instructions:
