02-02-2022
19:35
04:01
02-02-2022
19:35
04:01
Versa 2 Fitbit says new update is available, when I click on updating it versa2 shows update progress but comes back to Home Screen and the app continues to show update is available.
Tried restarting, resetting Versa 2 but no luck. Re installing app even installing it on new device did not help, called support, he said wait for some time and message will go away! But no luck in that as well so far.
02-03-2022 04:08 - edited 10-30-2023 03:33
Hi there, @Moaz. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2. I understand where your concern is coming from.
Have you made sure that your Fitbit app is up-to-date? Which FW version is showing your Versa 2 when you check the settings ( find the firmware version in the Settings app > About or Device Info)? Is your Versa 2 syncing without any issues? Do you have any MobileTrack or any other Fitbit device linked to your Fitbit account? If that is the case, please remove MobileTrack or the other Fitbit device and see if the message keeps popping up either on the Fitbit app or your Versa 2.
If the message keeps popping up, may I know if the message only appears on the Fitbit app or Versa 2 or even on both?
Keep me posted.
Best Answer02-03-2022 04:08 - edited 10-30-2023 03:33
Keep me posted.
Best Answer03-02-2022 05:45
03-02-2022 05:45
-Yes, I also tried using it on a different device (android) and on iPad, no luck!
-Current firmware version is: 35.72.1.15
- No Syncing issues, but the battery is draining really fast cant use it even for 24 hours without charging.
Yes (Removed it and added it again after a few days as its a good feature)
-Removed it, used it without this for some time, still no luck.
-It appears only on the app, no problems shown on versa 2, except the battery issue which has turned worse ever since I started seeing this pop-up:
Versa 2 Update Available
A firmware update is available for your versa2
And although it has a cross mark, most of the time cross mark does not work, so can't even close it.
