03-17-2024 06:22
03-17-2024 06:22
All of a sudden my screen is dark, flashing, with streaks going through it. Sometimes it goes totally blank but with a bright, blinding, white, completely solid, blank screen. Then it goes back to very black with whitish/yellowish flashing clockscreen, almost impossible to read with the streaks flashing through it. I have restarted multiple times but it continues the same. It had a really hard time syncing this morning but did eventually. I am hoping there is a fix to this. Any help would be appreciated, or do I need to call support? I have read through multiple posts and am not finding any similar issues. I have also searched YouTube, but am not finding anything there either. Thanks
03-17-2024 07:20
03-17-2024 07:20
This same exact thing happened to me when I looked at my watch this morning! It must be a software issue.
03-17-2024 08:11
03-17-2024 08:11
Something similar has been happening with mine lately, also. I figured it's because it's 6 years old and time for a new one ;). It didn't start doing this til I started wearing it in the shower so I think, even though it says you can, I probably shouldn't have done that.
03-17-2024 08:19
03-17-2024 08:19
03-18-2024 00:00
03-18-2024 00:00
Exactly the same is happening to mine. I can't get the restart to work. When my alarm went off it did come back for a couple of minutes, but is back to flashing again now.
03-18-2024 04:38
03-18-2024 04:38
03-21-2024 21:26
03-21-2024 21:26
Mine has been doing the same thing you all are experiencing. They are quick to blame third party apps or clock faces. I’m on my 2nd or 3rd replacement and it’s doing it again. I can’t even get it to reset either. It’s been doing it off and on with the blinding flashing lines for the past few days. Wish Fitbit would admit it’s a software glitch if more than a few have same issue or give us advice on what to do if we can’t do a reset.
03-31-2024 14:37
03-31-2024 14:37
Mines done the same today, working fine, vibrated and then the screen has got lines all over it, with faint time displaying
