09-11-2021 22:52 - last edited on 09-12-2021 11:13 by LiliyaFitbit
Hi there, I bought a fitbit from someone who hardly used it. I was washing dishes and looked down and the screen was hanging from part of the motherboard from the watch. (I'm assuming) What could I do to fix this? I pushed it back in and it still fell out again. The screen is still functioning and miraculously the inside is still dry.
I know I don't qualify for a replacement most likely so im unsure what to do except maybe glue it back in??
09-11-2021 23:06
09-11-2021 23:06
Hi @Astrolog if there is a jewelry/watch repair shop in your area, check with them. They might have just the tools and glue that would work. You could probably glue it yourself, but you'd need to research it a bit to be certain you're using the right kind of glue. After you've fixed it, you'd need to avoid getting it wet, which shouldn't be a problem. No need to wear it while showering anyway.
