10-24-2020 12:15
10-24-2020 12:15
About an hour ago I pressed the button on my Versa 2 to check the calories I had burned for the day and nothing happened. I charged the battery to 100% this morning so the battery had not run out. I have tried to restart the device as shown in the troubleshooting tips and it hasn't restarted. There are no lights on the device and when I charge it nothing seems to happen. It's not quite a year old and it is the 2nd device I have owned after encountering a similar issue with my 1st one. Is there anything else I can do to get the device working again? Thank you
10-24-2020 15:12
10-24-2020 15:12
I have had the exact same problem today!
10-24-2020 15:19
10-24-2020 15:19
I have the same problem today it’s 8 months old
10-24-2020 17:33
10-24-2020 17:33
I have the same problem today! Was 100% yesterday, just looked at it today. 3% battery, screen dead. everytime they do an update it's like amateur hour. I have to remove the device and start from square one. So irritating.
10-25-2020 02:27
10-25-2020 02:27
Me too! They sent me a replacement one and now I can’t update that one or connect it to my phone. It’s only about 5 months since I got this one- really unreliable
10-25-2020 03:07
10-25-2020 03:07
Me as well—Saturday I woke up and looked at it to check the time and it was dead.
10-25-2020 04:04
10-25-2020 04:04
Happened to me yesterday and I connected it to my computer and it came back!
10-25-2020 06:03
10-25-2020 06:03
mine wouldn't sync since yesterday evening, I just went to do a restart and it is stuck on the logo screen
10-25-2020 06:11
10-25-2020 06:11
I had to plug it in 3 or 4 times and it finally reset itself
10-25-2020 06:50
10-25-2020 06:50
I had the same thing happen WHILE on the phone with Fitbit tech support! The tech was troubleshooting my device. He performed a factory reset on it. It turned off and wouldn't come back on! He told me told let it charge and call back. Did that and the rep that picked said that I needed a device and they would offer me 30% off of a new one!! She said that they couldn't replace because it was over 12 months old. I said it completely shut off while YOUR tech support was troubleshooting it! I said that was unacceptable so she escalated the issue and that someone would be reaching out to me. Welp, it's been over a month and NOTHING. I will be contacting them again this week!
10-25-2020 11:30
10-25-2020 11:30
10-26-2020 11:38
10-26-2020 11:38
That happened for me too. But I had also changed the watch face. So one or the other worked!
