05-14-2020 09:04 - last edited on 06-23-2020 18:58 by MarreFitbit
This model I bought as had 3 replacements for my Charge 3 issues now my Versa 2 is frozen on msg screen and it has a red line when trying to sync I don’t seem to have much luck and I have no idea how to try to fix this
06-23-2020 19:02
06-23-2020 19:02
Hello there @Topcat31, welcome to the Community Forums. I'm sorry to hear that your Versa 2's screen is frozen and it's not syncing to your Fitbit app. I'll be glad to help you.
If you haven't done so yet, I'd recommend to restart your watch as follows: How do I restart my Fitbit device?
About the synchronization, I wondered if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 and higher, Android OS 7.0 and higher.
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
I suggest following the troubleshooting steps provided here: Why can't I set up my Fitbit device? and Why won't my Fitbit device sync?
Hope this helps, I'll be around if you need further assistance.
06-23-2020 19:02
06-23-2020 19:02
