06-18-2023
02:28
04:09
06-18-2023
02:28
04:09
has anybody had this happeN To their versa2, just noticed this morning its gone green and flickering so its virtually useless to me at the moment. Have done the reboot thing, holding down button till it reboots, and still same..see pic
06-18-2023 04:10
06-18-2023 04:10
Hello there, @Johnz555. Thanks for stopping by in the Fitbit Community Forums, trying to troubleshoot the issue with your Versa 2, and the image attached.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer06-18-2023 06:47
06-18-2023 06:47
yes ive done the restart and also changed the clock face as per your recommendations, but still same..
Best Answer06-18-2023 10:23
06-18-2023 10:23
I have the same issue. Is your fitbit watch working now? Please guide if you are able to resolve. Thanks
Best Answer06-20-2023 01:56
06-20-2023 01:56
It has now got worse...i..e there is just a kind of white face now, i've done as you;ve suggested and its basically useless. What is the course of action here , do fitbit repair them or what is the story ?
06-20-2023 01:56
nope its got worse, i've replied to the moderator on the case...dont know if anything can be done..
