07-04-2022
12:30
17:22
07-04-2022
12:30
17:22
I purchased my Versa 2 in January of 2021. This morning I found the screen display is so faint I can hardly see it. It won't react to my wrist movement at all, I have to push the button to see the display.
What can I do about it? Is there a "fix"?
Surely it (Versa 2) should last longer than 1 year 5 months and 18 days.
As it stands right now, it is totally useless to me.
07-04-2022 17:18 - edited 07-04-2022 17:19
Hello @Kathim1
Maybe your screen brightness got altered somehow. Go to your Versa 2 and tap settings then scroll down an tap brightness. You can set it for max if that helps. Other choices are Dim and normal .if this doesn’t help you can try restarting your Fitbit by holding down the button until you see the Fitbit Logo then release the button.
😃Please let me know if this answered your screen issue and helped brighten things up
Best Answer07-04-2022 17:18 - edited 07-04-2022 17:19
Hello @Kathim1
Best Answer07-04-2022 17:25 - edited 03-25-2024 07:46
Hi there, @Kathim1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from. @SunsetRunner Thanks for your help!
As per the description of your post, it seems that your Versa 2 is in sleep mode. When the sleep mode setting is on:
To turn off Sleep Mode, swipe down from the top of your screen. After your notifications appear, swipe down again to open the control center. Tap the quick settings icon. For more information, see How do I navigate my Fitbit device?
07-05-2022
01:26
09:24
07-05-2022
01:26
09:24
MegaBite, thank you so very much!
That worked!
I really appreciate your help. I've been a FitFit wearer for 10 years now
and I would be lost without it.
Thank you again!
Kathim1
Update: MarreFitbit,
Thank you! I did what you said and as it turns out, screen wake had gotten
changed. By following your suggestion, I noticed it.
I really appreciate your help! I rely on my Fitbit for so much and was lost
without it.
Thank you again!
07-05-2022 04:05
07-05-2022 04:05
That’s awesome @Kathim1! 😃 I’m happy that worked and your up and running again! I hope you enjoy the rest of your week and as always Happy Stepping!
Best Answer07-05-2022 09:23 - edited 07-18-2023 10:37
@Kathim1 Awesome! I'm glad to hear you're back on track. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
