11-30-2021
07:59
14:15
11-30-2021
07:59
14:15
From Day 1 My Versa 2 charge display is stuck and flashing low battery l
The watch itself always shows low battery and the App always shows it at 100 %.
The battery is working, I can go 5-6 days without charging.
I have tried Factory reset, uninstalled and reinstalled the app with no success
Any ideas out there?
Thx!
11-30-2021 14:15 - edited 02-14-2024 03:34
Hi there, @DMoon. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
Regarding the battery level on the Fitbit app, note that it updates every time you sync. That means that if your watch hasn't synced yet, your app will still show the battery percentage of the last sync.
While reading your post, it seems like your Versa 2 has run out of battery and it hasn't yet synced to the Fitbit app. That would explain both of the behaviors, your Fitbit app and watch. Once you charge your watch make sure to sync and you'll see that the percentage on your Versa 2 will match with the one on your Fitbit app.
If you haven't done so yet, please see Why isn't my Fitbit device's battery charging?
