04-19-2023
16:02
04:56
04-19-2023
16:02
04:56
My versa 2 screen keeps getting flashing white lines on the screen. I've looked on the forum at thr suggested fixes, I've soft started and full factory reset. It was OK for about 20hrs then started doing it again.
Can anyone suggest anything else to try please.
Thanks
Louplou.
04-20-2023 04:57
04-20-2023 04:57
Hi there, @Louplou.. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer04-20-2023 05:43
04-20-2023 05:43
Thank you for the tip. Sorry to say it didn't work. I've still got a flashing screen. ☹️
Best Answer04-20-2023 06:19 - edited 03-30-2024 03:29
@Louplou. You're very welcome! Thanks for trying the steps I recommended above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
I hope we can solve your issue soon.
Best Answer04-20-2023 10:06
04-20-2023 10:06
Thank you very much. X
04-24-2023 06:22
04-24-2023 06:22
A massive thanks to everyone who tried to help. Fitbit have said they will replace it for me. So I'm excitedly waiting on my post person. Thank you Fitbit.
