Versa 2 screen stays on
ANSWERED
Slightest movement of my hand and screen lights up and won't go to sleep unless I press the button
1 BEST ANSWER
Accepted Solutions
Hi there, @VivianCarper. Welcome to the Community Forums.
It seems like you have turned on the always-on display setting on your Versa 2. To turn it off, open the quick settings on your watch:
  • Swipe down from the top of the screen, and tap the quick settings icon
In the quick settings screen, tap the screen wake icon to adjust the setting.
  • When you set Screen Wake to Auto (Motion), the screen turns on each time you turn your wrist.
  • When you set Screen Wake to Manual (Button), press the button to turn on the screen.
For more information, see How do I see the time on my Fitbit device? or How do I navigate my Fitbit device?
Hope that helps.
3 REPLIES 3
Hope that helps.
Thank you!  Problem solved.  Thanks for the quick response. Sent from my Verizon, Samsung Galaxy smartphone
@VivianCarper Awesome! I'm glad to hear that the steps recommended did the trick.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
