12-13-2023
10:57
03:34
12-13-2023
10:57
03:34
11 hours ago my Versa 2 stopped syncing. It will not cone on. I've tried all suggested troubleshooting ideas to no avail. I've attached what comes up on the screen.
12-13-2023 14:00
12-13-2023 14:00
Hello @Barbara13
I moved your post from the Android platform forum to the Versa smartwatch product help forum as it seems your issue is with the device and not the platform.
Hopefully someone here will be able to help you.
12-13-2023 23:51
12-13-2023 23:51
HI @Barbara13 - you have probably cleaned the watch and charger contacts, however just in case you had a Versa, make sure you are using the the Versa 2 charger and try connecting to a PC as power source and listen to the connection/disconnection noises which will give some indication as to what is happening.
Also try several charges of 30 minutes and when you don't get that display when pressing the button, try holding the button for a full 10 seconds till it vibrates and the logo appears and wait for it to start. There may be enough charge for it to restart and then it might charge normally.
Otherwise the watch probably has a fault and it's worth chatting via the Fitbit App, Help & support section, Contact Customer support.
12-14-2023 09:07
12-14-2023 09:07
@Barbara13 I have a different perspective on your issue. That image is the critically low battery display. You wrote that you tried all the troubleshooting ideas, but I want to emphasize some points.
Laurie | Maryland
