03-16-2022
12:57
07:54
03-16-2022
12:57
07:54
My Fitbit versa 2 won't turn on. This morning it was working perfectly and tonight it's broken. It's fully charged and I've even tried restarting it by holding the buttons down for 15 seconds and still nothing. Everything else seems to be working, my alarm the vibrations and that little green light at the back is still flashing but my screen is still black. Can anyone help please?
03-16-2022 13:10
03-16-2022 13:10
I am having the exact same issue! Was fine this morning now my screen will show for a split second then it’s gone. Everything else on it seems fine
03-17-2022 07:56 - edited 06-23-2024 08:40
Hi there, @Aimee-y-c @Chanicealicia. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with the Versa 2 before reaching out.
Please confirm that you both have restarted your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
03-17-2022 08:57
03-17-2022 08:57
Try turning the Quick view (motion) setting off via the APP then reset your Versa to see if manual mode works.
If you have an iPhone & recently installed ios 15.4 (just released) it’s possible there’s a glitch causing prob w/your Versa. Mine wouldn’t sync after 15.4 install even though phone showed connected. Did forget device but then couldn’t re-pair. Signed in to Fitbit acct via browser, put Versa on charging cable & was then able to pair them. No probs since🤞
