08-10-2020
09:26
12:03
08-10-2020
09:26
12:03
My Versa 2 is only 8 months old and the screen is flickering and white lies running through which makes the screen hard to read but the screen is responsive and functioning. I have reset the fit bit multiple times and reset to factory settings but neither have worked?
What should I do next?
08-11-2020 12:08 - edited 10-03-2023 10:02
Hi there @Cathydx, welcome to the Community Forums. Thanks for the details shared in your post about your Versa 2's screen behavior and for taking the time to fix it prior to posting here.
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
