03-24-2022
07:09
07:59
03-24-2022
07:09
07:59
I guess it’s the latest update. I can’t choose a workout or scroll to other options like Starbucks, Pandora, etc. Screen also appears dim. I have restarted it, unpaired it from my iphone/re-paired it. Can anyone help with this?
03-24-2022 08:00
03-24-2022 08:00
Hi there, @Kikkim816. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
It seems that you've set your Versa 2 in Sleep Mode. When the sleep mode setting is on:
To turn off Sleep Mode, please swipe down from the clock face on your watch to access the quick settings. For more information, see How do I navigate my Fitbit device?
Hope that helps.
03-24-2022 08:00
03-24-2022 08:00
Hope that helps.
03-24-2022 14:05
03-24-2022 14:05
Hello! I’ve tried swiping from top, bottom, left and right. Nothing helps. Also, my settings are set to show my texts and vibrate when I receive a call…. It has stopped doing all these things. It only shows my clock screen. Please help again. Thank you for your help!
03-24-2022 15:00
03-24-2022 15:00
hi I have the same problem as well!! the screen turns on when i tap it, but it doesn’t respond when i swipe in any direction. i have an alarm which goes off every morning, but the screen is unresponsive so i can never turn it off!! at first, swiping still worked, but was slow. then, i could only swipe left and only press the bottom right corner. now nothing works. weird huh.
03-25-2022 05:11
03-25-2022 05:11
@Kikkim816 @hopekcbs Thanks for the details provided in your post above. Would you mind confirming if you both have followed the steps I recommended here? Based on the description of your posts, seems like your watches are in sleep mode.
If the above doesn't work, please restart your Versa 2 once again as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
03-25-2022 06:45
03-25-2022 06:45
Hello! Yes, I have tried all that you asked. I tried swiping on the screen (to exit sleep mode), even though I never turned this on. My watch still will not swipe (top, bottom, left or right). I also checked the app for the sleep mode and don’t see it there. Is there a way to try this from the app? I also restarted it again, with the instructions you gave and still no swiping and a semi-dark screen. Thank you for your help.
03-25-2022 06:58
03-25-2022 06:58
@Kikkim816 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
03-25-2022 07:29
03-25-2022 07:29
Tried all the above and nothing works.
03-25-2022 07:43
03-25-2022 07:43
yup, I have tried all of this too. It is definitely not sleep mode, because I always have sleep mode turned on, and am always able to use my fitbit. apart from the button to turn the screen on and off, the screen is completely unresponsive, although still showing the correct time. the alarm I have set still goes off at 8:30 every morning, except I have no way of turning it off since the screen is unresponsive, so just have to leave it until it turns off by itself 😂
03-25-2022 11:21
03-25-2022 11:21
I've tried these as well and I cannot swipe in any direction...
03-25-2022 19:50
03-25-2022 19:50
I am also having the same issue. I have restarted my Versa 2, restarted my phone, changed my clockface, and nothing will work. I have also updated my app and checked for Versa 2 updates. Sometimes it will change screens but usually not. Also, sometimes the screen rapidly scrolls through the different screens by itself. I am using a face by Fitbit that shows SpO2, zone minutes, pulse, etc. I hope you are able to find a fix.
03-27-2022 03:37
03-27-2022 03:37
The product is defective and not covered under warranty. What a waste of time and money. I’ll stick to using my Polar H10 chest strap. FYI It’s 54% more accurate in capturing heart rates in the cardio zone. Thanks for nothing Fitbit. If anything I’ll be in the market for an Apple Watch.
03-27-2022 03:39
03-27-2022 03:39
There is no fix. The watch is defective and you wasted your money. You might not get a replacement either as it only comes with a 1 year warranty
03-27-2022 03:40
03-27-2022 03:40
Congratulations. You now have an expense piece of plastic. There is no fix unfortunately
03-27-2022 04:49
03-27-2022 04:49
It is not in sleep mode . As I have tried everything that you all have recommended to others .
reboot watch
ubinstall and reinstall app on iphone
change my device pin
everything . Still nothing works . From the app on the phone I can change the face of the click , it changes as it syncs perfectly well with the watch .
you can not tap swipe left to right too to bottom on the watch.
as you can see I am not the only one this has happened to since the last update . The watch was working perfectly well all day Friday till this started to happen Friday night.
I have only had the watch for just over a year .
it’s frustrating because from what I’m hearing from others is that the watch us basically defective now and Fitbit will not do anything for it’s users if the watch is more than a year old .
I do hope that you will find a solution, as these watches do not come cheap. And you will have very many unhappy customers 😟😖😖😫😫
03-28-2022 12:52
03-28-2022 12:52
I am having the same problem. When I do get the screen to respond it will scroll through the options very fast and I have a hard time getting it to stop scrolling. I thought it was just my Versa but sounds like several others are having the exact same problem. Please let us know how to fix this problem.
03-28-2022 17:24
03-28-2022 17:24
03-28-2022 17:57
03-28-2022 17:57
This is happening to mine right now. I came to see if they were having something going on with their site. I can't swipe up or down, I can't check the settings on my watch, because my watch won't swipe. I'm just past the year warranty too.
03-28-2022 18:06
03-28-2022 18:06
You basically don’t have a watch that is useable anymore . Consider getting a new one , if you want another Fitbit than you need to call customer service .
sorry to be the bearer of bad news
03-29-2022 07:43
03-29-2022 07:43
I am having the same issue and it is infuriating.
