03-05-2021
01:49
05:50
03-05-2021
01:49
05:50
Calories burned has suddenly gone hirewire today! Its backdated issues to Wednesday??? Although until last Wednesday and Thursday were fine?? What has happened
03-08-2021 05:59 - edited 10-14-2023 11:52
Hi there @kayjay65, welcome to the Community Forums. Thanks for sharing the details about the issue with your calories burned.
By any chance, do you use MyFitnessPal? If so, keep in mind that if you sync your Fitbit at 11:00 AM, MyFitnessPal will only have information about your Fitbit calorie burn data through 11:00 AM that day. If only a partial day's worth of data is available, MyFitnessPal will combine the actual data from your Fitbit with an estimate of your calorie burn for the remainder of the day based on the daily activity level you selected when creating your MyFitnessPal account. This allows MyFitnessPal to create a more accurate estimate for your daily calorie burn based on the best data they have available from your Fitbit device at that time.
If the issue persists, I recommend doing the following:
If you continue experiencing difficulties, please revoke access to the integration with MyFitnessPal:
After relinking, you can verify that your accounts are syncing by using one of the following data points:
I've moved your post to Other Versa Smartwatches board for organization purposes.
Best Answer03-08-2021 05:59 - edited 10-14-2023 11:52
