10-11-2022
06:34
10:46
AndreaFitbit
10-11-2022
06:34
10:46
AndreaFitbit
Versa2 has big red X and “data not cleared. Sync and try again”
unable to sync and clear message.
Followed instructions, still have the big red X.
10-12-2022 10:51
10-12-2022 10:51
Welcome to the Fitbit Community, @KeiC. Thank you for mentioning that you have followed the instructions to remove the red x from your Versa 2.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
