12-13-2022 15:23
12-13-2022 15:23
Versa 2 records sleep each time but it doesn’t always record the different sleep stages, rim, light, deep etc.
12-13-2022 18:14
12-13-2022 18:14
@SunsetRunner , Nice to see you around. Thank you for your message.
The following conditions can prevent the recording of sleep stages:
- You record your sleep using the app instead of the Versa 2 automatic sleep detection.
- The watches' battery drains quickly when you go to bed (below 25%). This prevents a regular recording of the heart rate.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on the wrist. You can put your index finger between the bracelet and your arm without much resistance, so that your heart rate is recorded regularly and the sleep phases can be recognized.
If you tap the recording that doesn't show you any sleep stages, you should get a message explaining why you didn't get any. What is this message?
See you around
