Versa 2 sleep tracking not showing
I swipe up and i dont see sleep tracking data. I also dont see the option to enable it in the settings. There are three other options there: activity, heart rate , hourly steps.  My other versa 2 shows that.
4 REPLIES 4
@papillon333 Try restarting your Versa 2 and see if that will fix the issue of sleep tracking not showing up in the settings.  Also make sure you're syncing your Versa 2 with your phone in the morning to capture the sleep data.
Heather | Community Council | Eastern Shore, AL
Thanks for the  suggestion but rebooting didn't make any difference.
Any other suggestions?
@papillon333 When you open up the settings, are you still not seeing the full list of options?  Are you making sure to scroll all the way to the bottom of the list?  Sorry if that sounds repetitive, I just want to make sure I capture the entire issue.
Try removing the Fitbit from Bluetooth. Restart phone and readd Fitbit to Bluetooth.  Mine did the same thing when I first set it up.
