09-27-2019
13:30
12:32
DavideFitbit
09-27-2019
13:30
12:32
DavideFitbit
Hi, I've got a new Fitbit Versa 2. I can see the Fitbit but starts connecting and then cant. I'm charging it, I've turned it on and off and done the same with bluetooth. Any ideas?
09-27-2019
19:57
12:32
DavideFitbit
09-27-2019
19:57
12:32
DavideFitbit
09-27-2019 23:59
09-27-2019 23:59
Hi @Emmapasty78 What phone are you using? Is it on the Supported Devices List?
Try THiS Help Article on set up issues.
@Tyler007 If you bought your Versa 2 vrom a store then it is down to the store's policy. If from fitbit online you have 45 days in whaich to claim a refund. You will need to contact support
Helen | Western Australia
09-28-2019 02:41
09-28-2019 02:41
10-31-2019 14:42
10-31-2019 14:42
We purchased the Versa 2 for my partner and it would connect then drop out and say device not found so have checked all settings updated app uninstalled and re installed on 3 different phones now and the same thing happens as soon as you go out of the app the Fitbit is lost and not found again and has to be reinstalled. We got a replacement one from the store we purchased it from and exactly the same issue. No problems at all with my Versa lite. Today the Versa 2 is going back and we are getting the versa lite. The 2 has been a waste of money.
11-30-2019 11:29
11-30-2019 11:29
Hello, I had the same issues too. Did you have to send your first one back or did you keep it? I left mine off for a couple weeks and when I came around to it again it started working again. I've been using it for about a month now and it works without powering off. Give it a try if you still have the first watch.
