02-14-2021
05:25
12:01
02-14-2021
05:25
12:01
Hi all,
Can anyone help me get my fitbit Versa 2 to start working again?
02-14-2021 08:02
02-14-2021 08:02
What shows on the watch and what phone do you have?
02-15-2021 05:07
02-15-2021 05:07
02-15-2021 05:13
02-15-2021 05:13
Head to Settings on the Watch and turn on Heart rate.
02-16-2021 12:06 - edited 07-05-2024 13:04
Hi there @ChelseyLEdmunds, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
As @Guy_ has mentioned in the last post, I'd like you to perform the following steps below for this situation:
02-16-2021 12:13
02-16-2021 12:13
Mine did this after the update. I have discovered it was turned off. On your watch, go to settings then heart rate, and see if yours has too. Mine's fine again now I've turned it back on! Infuriating though!
02-16-2021 12:26 - edited 06-23-2024 07:46
@Naomignomed Awesome! I'm glad to hear your watch is fine again now. 🙂 Thanks for confirming that the steps we've provided above worked for you.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Have a nice day!
02-27-2021 09:14
02-27-2021 09:14
I was following these steps, however, once the device is in the charger one cannot access the reset button.
Now what?
02-27-2021 09:18
02-27-2021 09:18
True, just remove it to do so, and put it back on charge.
02-27-2021 19:12
02-27-2021 19:12
I can confirm these steps do not work. The HRM and its green lights still behave as if it was switched off.
02-28-2021 01:41
02-28-2021 01:41
@zgSHADOW Yours is a different problem
Check the watch is fully charged then restart the Versa 2 as follows
Shut down the watch [ Swipe left, Settings, at the bottom, About, at the bottom, Shutdown]
wait a minute
[Hold the button till it vibrates or logo appears] Wait for the clock to reappear. |
If that fails try Fitbit Support. They may be able to help you.
Possibly a fault due to a recent update, if it was working just before.
03-15-2022 07:38
03-15-2022 07:38
This worked for me! Hope it stays working now. Thank you!!
