08-08-2020
09:41
16:53
08-08-2020
09:41
16:53
My Versa 2 stopped giving detailed sleep records, including sleep scores for the last 2 weeks. I have tried restarting the device, logging off and on, and checked the heart rate monitor(which is working fine). I have an iPhone 8 plus. Could someone guide me on what the issue could be and how to resolve it?
08-10-2020 16:56 - edited 09-30-2024 10:43
Hi there @bvarma, welcome to the Community Forums. Thanks for the details shared in your post about your Sleep Score that has not been registered by your Versa 2 for the last 2 weeks. I appreciate all the steps you've tried so far in order to solve this inconvenience.
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see: What's sleep score in the Fitbit app?
If you are not receiving sleep stages, I recommend considering the following:
Give this a go and let me know how it goes.
08-11-2020 03:52
08-11-2020 03:52
I have same problem. Tried all of these for thr last 6 days. No luck. My old fitbit worked way better then this new watch. 😀
08-11-2020 06:24 - edited 09-30-2024 10:43
Hi there @Yogfan, thanks for stopping by in the Community Forums. I appreciate you've already taken the time to try and follow the steps I recommended above in order to get your Versa 2 tracking your Sleep Score again.
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We look forward to getting you back on track.
08-12-2020 03:48
08-12-2020 03:48
I do not get a sleeping heart rate under restoration. This has been going on for 4 days now. Can you help? Restarting did not solve the issue.
08-13-2020 09:41
08-13-2020 09:41
Hi there @JDefield, welcome on board. Thanks for letting us know about the issue of not getting heart rate data under restoration. I appreciate you already took the time to restart your watch. We’re currently working to resolve it and hope to have a fix soon. Be sure to keep your Fitbit watch and app up-to-date to ensure you receive the quickest resolution.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Please let us know if there's anything we can do to assist you in the meantime.
09-29-2020 14:02
09-29-2020 14:02
I bought my Versa 2 on July 25th. I have owned fitbits for at least 7 years. On my Ionic and on the Versa 2 I was getting sleep scores almost every night. On the Versa 2, I recently began getting 02 variation and HR. (the HR graph thru the night was not visible until recently) I updated my tracker last week and since then have only gotten the simplified sleep information, with the notification that a consistent HR was not obtained. I worked out today and my fitbit tracked my HR just fine. I am not sure what to do. Other than the update, I haven't changed any settings.
09-29-2020 17:02
09-29-2020 17:02
I am also having the same problem after years of use with a Blaze and then a first gen Versa. The presence of others with this same issue suggests there is a firmware update that isn't playing nicely with the app or something. I'm still within my 30 day return policy and strongly considering using it now that I see others have this same problem.
09-29-2020 17:23
09-29-2020 17:23
I have a Versa that is about 18 months old. I have never had a problem other than short battery life. About a week ago I noticed that it stopped recording my sleep. Then I noted that the green light no longer flashed. I tried the suggestion of toggling sleep and doing a reset. I did this several times to no avail. After my next charge the green light flashed a few times then went off again. Today I removed the Mindfulness stats tracker because I didn't what it and it had been added automatically at some point. Later on today I tried toggling sleep and doing a reset again and to my surprise the green light is working again. Now is this just a coincidence or did the Mindfulness tracker introduce a software bug that broke something?
09-29-2020 20:15
09-29-2020 20:15
I've had my Versa 2 for a year. My sleep tracker on my Versa has also been working well--until last night. You're right--this happened just as the Mindfulness tracking was added. I just removed that and hopefully mine will work also. Thanks for the tip.
09-30-2020 05:44
09-30-2020 05:44
Make sure you reset it. If the green light is flashing it will probably be working correctly. Let me know if it works.
10-01-2020 07:34
10-01-2020 07:34
Coincidentally, the night after I sent the above note, my Versa 2 started giving me the full sleep info. The last two nights have been fine.
I am now a happy camper.
