06-04-2022
02:29
05:34
06-04-2022
02:29
05:34
For four days now, my Versa 2 has refused to log any active zone minutes even though I am sure I've had several minutes those days due to workouts and brisk walks, as I have for the past 2 years since I've bought the product. For some unexplained reason, it stopped.
I've already tried turning it off and on again, tried giving it a full charge, wiped the sensor clean and looked if there were any firmware updates but everything is fine.
I cannot link it to an event either, as it was working fine one day, and then no longer the next.
Please assist
06-04-2022 05:38 - edited 06-05-2023 07:44
Hi there, @Ayame__. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
It seems like the heart rate might not be getting accurate readings, therefore, it won't provide you with AZM. With that being said, I'd recommend trying the following steps to make sure your heart rate is working:
For more detailed information, see What factors can affect my heart-rate reading on my Fitbit device?
Test your Versa 2 the next couple of days to see if it starts providing you with your AZM.
06-04-2022 06:25
06-04-2022 06:25
Thanks! I had indeed noticed the green light no longer flickered at the bottom of the watch and my heart rate readings were gone as well. Your solution fixed it!
06-05-2022 13:10
06-05-2022 13:10
Unfortunately, it seems to have only worked for a day. This morning it hadn't logged any of my nightly heart rates and when I went for my daily jog, no heart rate nor active minutes show. When I turn the watch over, I can no longer see the green led light at the bottom flashing (where I normally would see it when turned over). I have tried all your steps again, but to no avail. Could it be that a faulty light is the issue?
06-06-2022 06:57
06-06-2022 06:57
@Ayame__ I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
09-10-2022 18:38
09-10-2022 18:38
Had the same issue but now it has started working
