05-17-2023
05:29
06:09
05-17-2023
05:29
06:09
Hi all,
I have a Versa 2, which is fully charged and working well other than it isn’t tracking my stats. It IS tracking steps, floors, miles, kcals and resting heart rate. It is not tracking sleep, health metrics, time to get moving or anything else.
This has been going on since last Thursday and below are the steps I have tried to fix.
- updated Fitbit app
- force closed app
- turned off iphone
- synced app
- turned off/on Bluetooth
- checked/cleaned watch contacts (all seems fine)
- turned off/on Versa 2
- above steps carried out numerous times and in different orders.
Any advice welcome as to what else I can do, the watch functionality is pretty useless at the moment 😞
05-18-2023
17:33
16:56
05-18-2023
17:33
16:56
Hi @LauraMatt - in that case it's just possible the heart rate measurement is turned off or the watch thinks it is.
Go into the watch Settings and check the state. If it is turned off turn it on. If it is already on turn it off and restart the watch.
Then turn it on and restart the watch again.
That might help get you a reading.
Best Answer05-17-2023 11:51
05-17-2023 11:51
Hi @LauraMatt - if the watch is actually working fine, swipe up to get to the Today info to check, but there is a problem in the Fitbit App, Logout of the app and swipe off the active window.
Login again and click Edit and add the missing tiles then click Done and sync.
If it is not syncing see - Why won't my Fitbit device sync?
05-18-2023 17:24
05-18-2023 17:24
Hi Guy,
Thanks for your reply. I’ve checked the watch and unfortunately the watch is the same as the app, i.e it’s not tracking some of the stats. Both the watch and the app are missing the same stats although the tile is present. For example with the sleep tracking, it shows - -hr - - min, no score. The app shows the same and tells me I need to wear my Fitbit to bed.
05-18-2023
17:33
16:56
05-18-2023
17:33
16:56
Best Answer05-20-2023 07:14
05-20-2023 07:14
Hey Guy,
Thank you again for your advice, unfortunately it didn’t work 😞 but I do have a good news update!
I ended up contacting customer support and only then realised that the green light at the bottom of the watch wasn’t working. After trying a few other things, I factory reset the watch and it’s now working again!
05-29-2023 09:31
05-29-2023 09:31
I’m having the same issue with my sleep score and heart rate. What is the green light at the bottom of the watch (under the face of the watch where it is on your wrist touching your skin)? How do I make sure it’s working or get it working? Thanks.
20:45
13:29
ManuFitbit
06-06-2023
20:45
13:29
ManuFitbit
I did the factory reset - no luck. This is my 3rd Fitbit device over the past 10 years. I hope my Versa 2 can get back to full function. I’m so disappointed.
Hi Jenipie, apologies I missed your first message. The green light is the sensor which sits against your wrist on the underside of the watch.
Unfortunately I updated this thread too quickly as a day after the factory reset, my Fitbit stopped working again. I’m going to need a new one as well. You would expect more lifespan from a Fitbit than 2.5 years, especially when they cost what they do.
Best Answer06-09-2023 01:37
06-09-2023 01:37
I am having the same problem. All of a sudden the hear rate monitor no longer works. It doesn't track hear rate, sleep and active minutes.
This is my 3rd versa in about 6 years as the first 2 broke when I tried to use them to track swimming! Lasted 3 months and then stopped working.
Best Answer06-09-2023 08:47
06-09-2023 08:47
I’m having the same problem - started on June 1st - I received sleep matrix one time since then and that was the day after I called tech support. Just called tech support and they tell me it’s the way I am wearing the device - so after two + years I am wearing the device incorrectly - what a joke
Best Answer06-10-2023 09:58
06-10-2023 09:58
So - after contacting customer support again yesterday - today when I opened the app I had to log in - never had to do that in 2+ years - after logging in and syncing my Versa 2 guess what? I now have sleep metrics back. Fitbit did something and fixed the problem - guess I now what and see what happens - I was getting ready to switch to Apple
06-10-2023 19:38
06-10-2023 19:38
I think with so many having recent issues with the heart rate and sleep stats - Fitbit Versa 2 is shutting itself down. I wonder if the company can do it, or it’s just a the luck of the draw that we are all having the same issues. I’m thinking of another smartwatch also and have started looking at other brands. If any switched to another smartwatch, let me know what you like. Thanks!
06-11-2023 05:16
06-11-2023 05:16
I think you might be right in the same way as apple phones appear to be shut down after a while. I’m also wondering if a recent Fitbit update was rolled out that might have had glitches? I would like another Fitbit simply because of all the info stored on my app, not sure if it would be possible to transfer it over if I bought another brand of smart watch. Don’t want to buy a Fitbit again if this is a common occurrence though.
06-11-2023 06:46
06-11-2023 06:46
