06-21-2023
05:31
05:52
06-21-2023
05:31
05:52
I woke up a couple of days ago to see my watch face was dark. I reset it to get it back, but now the green light on the bottom is no longer flashing and it is no longer recording my heartrate.I have tried everything else to get it back like reseting and resyncing, but it didn’t work. I’ve only had this fitbit to replace my old versa 2 for about a year.
I don’t need the heartrate monitor that badly, but it would be nice to have. Is there some other way to get it back, or did a simple reset I’ve done hundreds of times just break it somehow?
06-21-2023 05:54
06-21-2023 05:54
Hi there, @Shinehollow. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done, I'd recommend trying the following steps to make sure your heart rate is working:
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device?
Best Answer06-21-2023 10:13
06-21-2023 10:13
This does not work.
this is my 2nd versa that did this to me. No one from fit bit can help or fix the problem. This is complete crap and eve worse that no one can fix it
dont buy fit bit products
Best Answer06-23-2023 17:28
06-23-2023 17:28
This happened to me too. Randomly stopped working. Now refuses to work despite resets and doing that sync suggestion. Won't track heart rate or sleep now.
