04-14-2022
09:55
14:08
04-14-2022
09:55
14:08
Hi,
I have a Versa 2 and about 2 weeks ago the heart rate sensor stopped working and the sleep tracker also stopped. I have tried enabling, disabling, restarting and updating but to no avail. From the forum pages this appears to have happened to a lot of customers. Is there a fix?
Peter
04-14-2022 14:10
04-14-2022 14:10
Hi there, @Peterkenfly. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
As a first approach, I'd recommend trying the following steps to make sure your heart rate is working:
Also, for more detailed information, see What factors can affect my heart-rate reading on my Fitbit device?
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that in mind, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
Best Answer04-14-2022 14:36
04-14-2022 14:36
04-15-2022 04:55
04-15-2022 04:55
@Peterkenfly We‘re taking your comments and sentiments in regards to our products into consideration and I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer04-16-2022 13:16
04-16-2022 13:16
Here I thought I was the only one with this issue. Ever since the update everything has basically stopped working.
04-16-2022 14:41
04-16-2022 14:41
It is a common problem. I contacted customer support and as it was still in warranty it will be replaced.
