08-20-2020
17:41
11:36
08-20-2020
17:41
11:36
My Versa 2 has stopped tracking my heart rate and sleep. How do I get that functionality back?
08-21-2020 09:44
08-21-2020 09:44
Hi there @Meira3, welcome to the Community Forums. Thanks for letting me know that your Versa 2 has stopped tracking your heart rate and sleep data. I'll be glad to help you.
As a first approach, I'd recommend trying the following steps to make sure your heart rate is working:
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device?. Keep in mind that active minutes are also calculated by your heart rate.
On the other hand, I recommend considering the following in order to get sleep stages:
Let me know if the steps provided work, I'll be around if you need further assistance.
08-21-2020 09:44
08-21-2020 09:44
08-21-2020 11:09
08-21-2020 11:09
Sorry, none of this worked. What is your next suggestion?
08-21-2020 11:38
08-21-2020 11:38
Hi there @Meira3, thanks for the update. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know.
08-21-2020 13:28
08-21-2020 13:28
Thank you for your help. Support has already contacted me and we're working on this.
Diane
08-21-2020 14:10
08-21-2020 14:10
Hey @Meira3, you're welcome. I'm glad to hear they are already working with you. 😉
I'll be around if there's anything else I may do for you in the meantime.
02-08-2021 21:02
02-08-2021 21:02
Hi there!
i also am having this same problem. My versa suddenly stopped tracking sleep and heart rate. It started up on its own for one day and then stopped again. I tried the above trouble shooting option but this did not work ☹️ Any suggestions?
02-09-2021 02:55 - edited 09-08-2023 09:47
Hi there @ToriLori, welcome on board. I appreciate you had followed the tips and recommendations provided above. I understand how you must be feeling.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. I'd suggest to share this community link (thread) so our Support Team can be aware of all the steps you've done already, this way you can also avoid repeating yourself again.
