09-30-2021
04:14
05:56
09-30-2021
04:14
05:56
Versa 2 heart monitor stopped working and calories burned was not correct. The green lights are not flashing as they usually do....already tried resetting and that hasn't worked
09-30-2021 05:57
09-30-2021 05:57
Hi there, @Chrissy242. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
As a first approach, I'd recommend following the steps below:
For more information, see What factors can affect my heart-rate reading on my Fitbit device?
Hope this helps.
09-30-2021 06:50
09-30-2021 06:50
Thank you for trying to help Unfortunately it did not work. The green sensors are not lighting up. Not sure what's happening 😕😔😔
09-30-2021 06:56
09-30-2021 06:56
@Chrissy242 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
10-04-2021 03:54
10-04-2021 03:54
Still not working. 😔😔. I was told via the online chat forum to factory reset, it did not work.
