02-13-2022
21:03
06:51
02-13-2022
21:03
06:51
I love using my Fitbit Versa 2 Every day and hardly take it off but for some reason it suddenly stopped showing my heart rate. The green light is coming on the bottom and my body presence is detected by the watch but it just won’t show my pulse rate. Has been going on for four days and I really don’t want to have to buy a new one since everything else works fine.
02-14-2022 06:52
02-14-2022 06:52
Hi there, @FaultFinder. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 2. I understand where your concern is coming from.
As a first approach, I'd recommend following the steps below:
For more information, see What factors can affect my heart-rate reading on my Fitbit device?
Hope this helps.
02-14-2022 06:52
02-14-2022 06:52
Hope this helps.
02-14-2022 15:25
02-14-2022 15:25
Thank you so much! It turns out that heart rate tracking was off in settings. I’ve turned it on now and the watch works just fine!
02-20-2022 15:57
02-20-2022 15:57
Thanks for your responses. I’ve tried everything you’ve recommended. I’ve even tired each of these steps on multiple days, just to make sure all of my hardware / software was properly updated. Nothing is working. - I can’t monitor my heart rate or sleep, of course, since it’s dependent on HR - these are both more important to me than the steps tracking. Thank you.
02-20-2022 17:02
02-20-2022 17:02
Heart rate stops working is a common problem that Fitbit won't address or admit that it's a fault of theirs.
Check the forums. Lots of complaints.
02-20-2022 17:49
02-20-2022 17:49
Seems to be an issue with many trackers and smartwatches, my wife has had that same problem with her Apple watch 5 and 6. I had it stop tracking my heart rate on my Versa 2 for several seconds up to as long as a minute however I have not had that issue with my Fitbit Charge 5. Both Apple and Fitbit told us to make the bands tighter, clean the sensors and even reset our devices. I do believe that the tech will become more efficient and reliable in the near future.
03-03-2022 11:09
03-03-2022 11:09
I too am having the same issue. I have done everything you have said to do several times including several factory resets. It works for about 30 minutes then nothing again. I’m constantly resetting my versa 2. I think there should be another firmware update to the versa 2 instead of several app updates.
03-04-2022 05:59
03-04-2022 05:59
Hi, unfortunately I too have been experiencing this issue for some time now. I have followed all the suggested steps on multiple occasions, cleaned the sensors on the back with rubbing alcohol as suggested in @AlvaroFitbit’s post on 06-13-2018. I even went back to factory settings but my heart rate and sleep are still not being tracked. I’m at loss what to do next to fix the issue. Can you please help? I bought the watch in July 2020.
05-16-2022 09:39
05-16-2022 09:39
I have tried this and mine is still not working, and hasn’t for months
05-16-2022 17:20
05-16-2022 17:20
Same here!
The heart rate monitor stopped working after I updated the firmware to 35.72.1.19
According to the repair shop where I brought it to get checked, it is a very common issue with the Versa 2 after this particular update.
I wish Fitbit would do more than simply offer a discount for a new watch since mine was working perfectly fine before that firmware update...
