06-24-2022
23:41
05:49
06-24-2022
23:41
05:49
My versa 2 has stopped detecting heart rate. I have performed all the necessary resets and updates but still nothing. It’s tracking steps.
06-25-2022 05:52 - edited 03-25-2024 07:46
Hi there, @Kimmy404. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
I've seen you contacted our Support Team after posting here, but your chat got disconnected. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Nevertheless, I'd recommend try the following:
For more information, see What factors can affect my heart-rate reading on my Fitbit device?
06-25-2022 07:50
06-25-2022 07:50
Done all of the above but still no lights for heart rate sensor
06-25-2022 11:57 - edited 03-25-2024 07:43
@Kimmy404 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
06-26-2022 07:41
06-26-2022 07:41
Did you get this resolved? I have been having the same issue. Thx!
06-29-2022 13:43
06-29-2022 13:43
No still no luck.
06-29-2022 19:52
06-29-2022 19:52
Did this as well for same issue. Started this after update from FitBit. This didnt work. Tirning HR on and Off doesnt work. Rebooting doesnt work. And reset to factory defaults doesnt work either. Once he n awhile i may get it to work for a little bit then lights are back off again. Nothing left to try. Was working just fine until update that added Afib tracking. Now what bc it seems your update caused this issue. Help !!!!
