08-07-2022
22:12
16:50
08-07-2022
22:12
16:50
Please help, my heart tracker won't detect my heart rate anymore....
08-08-2022 04:54
08-08-2022 04:54
Hello @MelVas
Go to your Versa 2 and swipe left twice to get to your settings. Tap the settings gear wheel then scroll down and make sure your heart rate is on and wasn’t accidentally disabled. If you find the heart rate was already on, turn it off then sync your tracker then turn it back on then sync your tracker again.
If the issue continues you can try restarting your Versa 2 by holding down the button on the side until you see the Fitbit Logo then release the button. It will then vibrate to indicate the restart is completed.
If it still remains a problem look here to see tips that might help: https://help.fitbit.com/articles/en_US/Help_article/1582.htm
😉 Hopefully this provides you with an answer. Please let me know
Best Answer08-08-2022 16:51
08-08-2022 16:51
Hi there, @MelVas. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As @SunsetRunner has suggested, please try the following steps:
For more information, see What factors can affect my heart-rate reading on my Fitbit device?
Hope this helps.
08-09-2022 15:53
08-09-2022 15:53
I am having the same issue and have tried all the trouble shooting and it's still not working, the sensor isn't on at the back of my watch
Best Answer08-09-2022 18:33
08-09-2022 18:33
I'm having the same issue and also have tried all of the aforementioned tips multiple times.
Mine has also stopped notifying me to get up and move at 10 till the hour if I'm not up to my 250 steps yet.
For as much as we pay for these watches I would like it to work longer than a year.
