08-20-2022
15:00
05:59
08-20-2022
15:00
05:59
My Versa 2 stopped tracking heart rate. There's no green light on the back anymore and it just shows -- BPM.
I've tried factory resetting, restarting the Fitbit, Turning heart rate monitor off and on, Removing the Fitbit from the app and re-adding it and nothings working!
I've seen a lot of other people have the same issue. Has anything helped ??
08-20-2022
23:28
16:35
08-20-2022
23:28
16:35
Hi @AmalieF - this can happen if the watch got wet or if it follows a firmware update.
If it doesn't work after a factory reset the watch has a fault.
The quickest way to resolve it if it is under warranty, 1 to 2 years depending on country law, is to replace it over the counter where you bought it, hopefully.
Best Answer08-27-2022 06:01 - edited 06-24-2023 07:12
Hi there, @AmalieF. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. @Guy_ Thanks for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
