09-30-2024
10:57
05:27
09-30-2024
10:57
05:27
My fitbit versa 2 has died after swimming yesterday just showing a red light on back of the watch screen is completely blank any ideas thanks
10-02-2024 05:32
10-02-2024 05:32
Hi there, @Iaintrucker72. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 2 stopped working after swimming with it. I understand your concern, I will do my best to help you with this!
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, I'd recommend trying the steps below:
10-05-2024 03:35
10-05-2024 03:35
Thanks for the reply versa 2 won't even charge or switch on think the battery is dead
10-07-2024 08:07
10-07-2024 08:07
@Iaintrucker72 Thanks for getting back to me. I'm sorry to hear that the steps provided didn't work.
Sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
If the issue persists after trying the above, as our last resort, I'd recommend performing a factory reset on your Versa 2. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Versa 2 and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
