11-28-2019 09:46
11-28-2019 09:46
This problem happens more and more frequently. Where the versa 2 simply does not respond to my touch.
My normal workaround is to hold the button until it restarts. After several restarts it will allow hyperslow scrolling. After that it will crash before I can get to the about screen. After the crash I can usually scroll to the about screen and then do a shutdown. After a shutdown it will work normally for awhile before repeating. I waste about 10 minutes for this precedure.
i have tried a factory reset -and only using the factory default click face, apps and settings. But the problem just keeps happening more frequently. A smart watch that would respond to me is not very smart.
05-13-2020 16:13
05-13-2020 16:13
05-14-2020 05:23
05-14-2020 05:23
If I had an iPhone I would have an apple watch.
05-14-2020 19:42
05-14-2020 19:42
I would too if I had an iPhone. I have been looking into Garmin because I really enjoy the long battery life. I know the iPhone has to charge daily which I know I'll forget to do. 5 to 7 days with the Garmin.
09-26-2020 11:38
09-26-2020 11:38
What is their email address so that I can send them an email as well because I'm having the same issue.
09-26-2020 18:54
09-26-2020 18:54
Mine is doing the same thing I've probably had it less than a year where do I send the email?
09-27-2020 00:38
09-27-2020 00:38
03-28-2022 15:02
03-28-2022 15:02
Whew! Thank you so much for your work around of holding the button until it went off. Worked for me and it will now respond to touch again. You saved me so much frustration!
