03-19-2022
06:35
10:15
03-19-2022
06:35
10:15
I have a Versa 2 that is constantly flashing the opening logo but with a white background. The screen lights up like this for 10 seconds then goes black for 10 seconds then lights up again...repeats this cycle as long as it is on the charger. I have cleaned the back of the watch, the charger itself and tried resetting the watch. I took it off the charger for two weeks to ensure it lost all charge, put it back on the charger and when it gained a charge it started the cycle all over again.
03-19-2022 10:16 - edited 01-08-2024 05:10
Hi there, @OldFiddler. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done, please follow the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
03-20-2022 03:08
03-20-2022 03:08
I have the same problem with my Versa Lite since yesterday. I tried the steps that you proposed. When I started the setup of my versa lite process, the app recognize the watch and ask me to enter the 4 numbers displayed on the watch: the problem is that the watch continues to flash the logo every 10 seconds and no code appears. I don't know what code to enter!
03-20-2022 14:27
03-20-2022 14:27
So I have tried to do all of the steps previously and now the Fitbit is just flashing black and white stripes every ten seconds, no logo anymore. I am guessing the watch has died. When I press the reset button and hold it there is never a response or vibration. It seems the display just keeps deteriorating. I am thinking it is beyond the warranty (about 16 months old) and is just ready for the garbage as I have found no tips to bring it back. The battery charges and will last quite a while off the charger with the flashing of garbage on the screen.
03-21-2022 01:29
03-21-2022 01:29
03-21-2022 10:37 - edited 11-26-2023 16:20
@OldFiddler @PFO56 I appreciate you had followed the tips and recommendations provided above. We‘re taking your comments and sentiments in regards to our products and services into consideration.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
