Versa 2 stuck on Fitbit logo
ANSWERED
After a pretty normal day, I put it into to charge overnight and came back to this, and it not making it past the logo screen?
1 BEST ANSWER
Accepted Solutions
Hi there, @Ambitiousrick. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2 and the image attached.
As a first approach, please restart your Versa 2 suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work, please try the following:
  • Unpair your Versa 2 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues updating your Fitbit device, see Why can't I update my Fitbit device?
If nothing seems to work, please follow @Odyssey13's advice and chat with us online or give us a call. Click here to get connected.
2 REPLIES 2
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
Stepping in the U.S.A. since September 2013. Android 14
