04-10-2023 12:59 - last edited on 04-11-2023 06:22 by MarreFitbit
Hello I have had had my Fitbit Versa 2 for a little over a year, when I charged it this weekend it would only display the fitbit logo for 10 seconds. I never get any other screen the Bluetooh is connected and indicates I have a 100% charge but fails to sync. I never get any other screen and can not the Fitbit so can not factory reset it. I did try the hold in button - release - quickly press and hold again. I never get any vibration. When on the charger the fitbit logo will go on and off but I never get any other screen.
04-11-2023 06:23 - edited 06-17-2023 10:23
Hi there, @Fit2Fithgt. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues updating your Fitbit device, see Why can't I update my Fitbit device?
04-11-2023 06:35
04-11-2023 06:35
Thank you for your response, I did follow those steps with support. Now the only thing my Vessa dose is to flash the fitbit logo every 20 seconds until the battery is dead. It never fully resets, since it is out of warranty I was provided a discount code to purchase a new device which I have done.
Thank you and have a great day.
Todd
04-11-2023 06:41 - edited 06-19-2023 04:49
@Fit2Fithgt You're very welcome! I'm glad to hear our Support Team was able to help.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
