Versa 2 stuck on Fitbit logo
 Fitbit went to this screen and now wont connect via Bluetooth. Tried reset
2 REPLIES 2
Did you try turning off your Bluetooth and turning it on again.   Hopefully you get your Versa 2 working again.
Hi there, @Kvr82. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2 and the image attached. I'll do my best to help you with this.
In addition to the steps recommended by @Steels07, please try the following in the order listed:
  • Unpair your Versa 2 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 2.
  • If there is no connection, restart your Versa 2.
  • Once your Versa 2 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
