Versa 2 stuck on message "Data not cleared, Sync & Tried again"
ANSWERED
My versa 2 I had off a friend is saying Data not cleared sync and try again
1 BEST ANSWER
Accepted Solutions
Hi there, @Maddogluna123. Welcome to the Community Forums. Thanks for the details provided in your post.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Setup your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
1 REPLY 1
