01-01-2022
06:27
10:19
01-01-2022
06:27
10:19
Data not cleared. Sync and try again. Message. Not sure how to clear this.
01-01-2022 10:25 - edited 08-03-2023 12:12
Hi there, @DAS1955. Welcome to the Community Forums.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
03-29-2022 23:04
03-29-2022 23:04
This happened to me last night. I rang the chat help and was on there for some time to no avail. It doesn't matter if I unpair because the watch isn't pairing with anything due to the above message on the watch face. This watch is now a brick on top of my Ionic which I threw away last October because it was getting hot to touch and the battery died (conveniently before the recall where they will not replace it even after their records clearly show I did have an ionic). This will be the last fitbit I buy.
