12-08-2020
12:46
12:58
12-08-2020
12:46
12:58
My heart rate wasn’t working so I did Factory reset. After that, it says ‘Data not cleared sync & try again’ but it won’t sync on the Fitbit app.
So now I can’t use it because every time I turn it on it says ‘Data not cleared’
Help please
12-08-2020 13:02 - edited 10-08-2023 04:35
Hi there @MMA1995, welcome to the Community Forums. Thanks for troubleshooting your Versa 2 before posting in the Community.
Please note that the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings. With that being said, please try the following steps to solve the issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer12-08-2020 13:02 - edited 10-08-2023 04:35
