06-28-2021
14:32
16:59
06-28-2021
14:32
16:59
The screen says, Data not cleared Sync & try again. It won’t sync. It won’t do anything. Deleted app and reinstalled.
Deleted from Bluetooth and reinstalled.
Nothing is working?
Everything google said to do, I’ve done.
Please help, only got the watch in April
06-28-2021 17:01 - edited 08-28-2023 05:24
Hi there, @HanHenPT. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer06-28-2021 17:01 - edited 08-28-2023 05:24
