Versa 2 stuck on message "Data not cleared, Sync & Tried again"
ANSWERED
I did a reset of my Fitbit Versa 2 and now I am getting a red circle with an X in it and it says Data Not Cleared Sync and Try Again. Please help if anyone knows what I should do?
1 BEST ANSWER
Accepted Solutions
Hi there, @Kireastpark18. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Setup your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
1 REPLY 1
Hope that helps.
