08-22-2021
05:36
09:19
08-22-2021
05:36
09:19
The data not synced message keeps displaying. I’ve done a factory reset the Versa 2, uninstalled and reinstalled the app, reset the Bluetooth connection and it still won’t work.
08-23-2021 09:20 - edited 11-24-2023 02:20
Hi there, @mmestre91. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
08-22-2021 07:07
08-22-2021 07:07
In the Fitbit app click the profile photo and try "+ Setup a Device".
After a factory reset it needs to be added, just like a new watch.
Best Answer08-23-2021 09:20 - edited 11-24-2023 02:20
Hope that helps.
11-02-2021 11:31
11-02-2021 11:31
Did not work. Do I need to do a factory reset? If yes, how?
Best Answer11-04-2021 11:33 - edited 11-02-2023 03:18
Hi there, @BennyB2577. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit device before reaching out.
I've seen you contacted our Support Team after posting here and they're now helping you with this matter. Please stay tuned to your inbox for updates on your case.
See you around.
